Rocker arm question
Old Jun 26, 2002 | 04:10 PM
Hung Start67's Avatar
Rocker arm question
Heys guys question here...92 z..l98..was wondering..im looking for easy bolt on performance and was looking at changing the rocker arms to 1.6 instead of 1.5..have read a few articles where it has bumped up the ponies anywhere from 15-20 horse...was just curious if anyone out there has done this mod..thanks guys..later
Old Jun 26, 2002 | 05:07 PM
ede's Avatar
ede
i wouldn't count on seeing that kind of results ,bolt on a less restrictive exhaust system ought to do you more good.
Old Jun 27, 2002 | 11:08 AM
Vader's Avatar
HS67,
I did some research when changing mine. At one time, the Crane adverts indicated a 16.7 HP increase and similar increase in torque by changin to their 1.6: stamped roller rockers on a stock L98. I swapped them on my weenie LB9 and certainlty don't feel like I gained even 10 HP, but it couldn't have hurt, either. At least the roller tips will reduce friction and heat, and minimize valve tip and guide wear. The reduced friction and wear have to be worth at least something, but you have to be wary of advertised HP gains. Generally, those are done as a best-case situation where all other modifications are done and the item in question is definitely the weak link.
Old Jun 27, 2002 | 11:31 AM
87transam5.7tpi's Avatar
I was also told by summit taht you have to have tall centerbolt valve covers AND use the crane gold ones if you want rr's on centerbolt heads. is this true? because then you are looking at like $100 for covers + $300 for rr's I might as weel get some nitrous oxide for that. :-)
Old Jun 27, 2002 | 02:10 PM
rockers
thanks vader..will hold off on them for right now.
SLNTSCPE
Aug 22, 2015 09:15 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
Cameeeero
Aug 20, 2015 03:06 AM
redmaroz
Aug 16, 2015 11:40 PM
