Fastburn heads in a 305.
Old Jun 26, 2002 | 06:48 PM
Beast5spdGTA's Avatar
Car: 2007 Corvette Z06
Engine: LS7
Transmission: 6 speed
Will the valves hit the cylinder wall on a stock 305 with 214/220 cam with ~.500" lift?
I don't want to know how bad of an idea it is or just get a 350 anything like that, I just want to know there will be interference between the valves and the cylinder wall.
I've heard that even 2.02/1.60 valves will clear if the cam is small.
Old Jun 26, 2002 | 07:34 PM
Ride4ME's Avatar
Use a "colder" cam and you'll be fine.
Old Jun 26, 2002 | 08:28 PM
iroc22's Avatar
With the Fast Burn's 2.00/1.55 valve setup, I wouldnt worry about hitting the cylinder walls until you see lifts of .600"
I've seen 2.02/1.60 valves installed on a 305 and they clear. Shrouding doesn't even occur until lifts of .550" and we estimated that the valves would hit the deck at like .580-.600" or so. That's with a 60cc chamber.
Jake_92RS
Jan 28, 2020 10:37 PM
92projectcamaro
Jan 18, 2016 08:00 AM
509 camaro fan
Sep 6, 2015 10:43 AM
z28guy134
Sep 1, 2015 11:50 PM
