Steering col. housing will not come off
Old Jun 26, 2002 | 08:45 PM
Joel Geerling's Avatar
Car: 91 Formula
Engine: 305 TBI
Does anybody know where I could find a spelled-out procedure for changing the actuator rack in my steering column? I feel stupid posting here every other time I get stuck trying to figure out how to take the column apart.
Now I can't figure out how to remove the steering column housing from the steering column housing support. The housing pivots on a pin (with threads on one side) that runs through both - do I have to remove this? If so, how?
Sorry if I sound frustrated - I have been blowing the only few free hours I have after work when I can get a ride up to my parents house, only to have to get a ride back each time... this is taking forever!
Old Jun 26, 2002 | 08:50 PM
@ZZKKER's Avatar
Car: 86 iroc, 87 iroc, 89 iroc, 89 formula, 84 supra, 85 trans am
Engine: t\a motor 355 lt1 intake, t56,the works, 89 roc 427 sbc tt project
Transmission: to many to list
Axle/Gears: 9bolt 4:10 in the T/A
i deal with this everyday. you have to get a speacial tool from the snap on man that costs 8.95 that threads into to pin and pulls ot out. it is like a mini steering wheel puller.
anthony
Old Jun 26, 2002 | 09:40 PM
2vmodular's Avatar
a self tapping sheetmetal screw, pair of visegrips and a flat blade screwdriver can be used if you do not have the proper tools to remove the pivot pins. first thread the screw into the pivot pin, then put visegrips onto the screw, and finally wedge a screwdriver in between the column and the pliers. then pry outwards being very careful not the break the screw in the process.
Old Jun 27, 2002 | 07:27 AM
Car: 91 Formula
Engine: 305 TBI
Thanks for the advice... I ended up finding a bolt that fit & threading it in w/a washer then prying out agains the washer... tonight I'll try to get things back together (can't wait ).
Old Jun 27, 2002 | 08:53 PM
@ZZKKER's Avatar
hey whatever works. i like using the tool better though, looks more profesional
Old Jun 27, 2002 | 10:37 PM
Vader's Avatar
8-32 machine screw, ¼" socket for about a ½" hex as a drift, a washer, and an 8-32 nut. There's your puller. A self-tapping screw can ruin the threads in the pivot pin, sticking it in there forever, or until you tap new threads.
83 Crossfire TA
Jan 3, 2016 01:26 PM
bubbaz28
Sep 18, 2015 02:09 PM
Ikes 91Z
LSX and LTX Parts
Sep 13, 2015 09:03 AM
punkmaster98
Sep 8, 2015 09:45 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
