My Z is making a horrible sound
Old Jun 27, 2002 | 07:45 PM
SX Stinger's Avatar
Car: 84 Z28 "Holly" (SOLD)
Engine: Carbed 305
Transmission: TH350
Recently my Z28 has started to make a funny sound. It sounds like the fan is slapping the fan shroud until the car shifts into second and then it goes away. I have already trimmed thye fan shroud and it did not help any and the shroud is also bolted down tightly. What is wrong with it? The sound only occurs when i start from a dead stop and the harder I press the gas the more noticeable it is. HELP!!!
Old Jun 28, 2002 | 11:14 AM
Vader's Avatar
SX,
The fan shroud may be attached firmly, but I'll guess that the engine isn't. Better check the engine mounts for breakage.
Old Jun 28, 2002 | 11:01 PM
SX Stinger's Avatar
Engine: Carbed 305
Transmission: TH350
Vader,
Old Jun 28, 2002 | 11:07 PM
RJR99SS's Avatar
maybe check the plastic flywheel shield?
SX Stinger's Avatar
Engine: Carbed 305
Transmission: TH350
Vader,
Thanks for the advice, but when I was having a problem of rough vibrations from the engine the first thing I checked was the engine mount s and they are solid and still in tact, they are only a few months old. At idle or when i rev it up in park the engine torques but stays firm it doesn't get sloppy , it vibrates due to the power but thats it and it is a good vibration. It is bugging the crap out of me too. It isnt a great thing to have happen to your car when a couple of good looking girls pull up next to me and they start checking my car out ( along with me). It kinda makes my car look like crap when i step on the gas and it sounds like my car is falling apart.
thanks
SX
Old Jun 30, 2002 | 10:08 PM
SX Stinger's Avatar
Engine: Carbed 305
Transmission: TH350
Thanks for all your quick replies and suggestions. I was able to fix it. As I said before the fan shroud was tight but the problem was that it flexed quite a bit so when the fan began to spin as the engine sped up the fan was actually pulling the shroud towards it and therefore I heard the fan trying to devour my shroud. I was abple to slot the bolt holes and pull the shroud away from the fan and now my Z is sounding good again
Drew:lala:
92camaroJoe
Jul 29, 2023 07:57 PM
xxx3man`
Sep 23, 2015 10:37 PM
Polo Z03
Sep 10, 2015 06:43 PM
db057
Aug 22, 2015 08:17 PM
92camaroJoe
Aug 13, 2015 06:07 AM
