Vacuum pump to check brake booster?
Car: 1982 Z-28
Engine: 383
Transmission: Turbo 350
Axle/Gears: Det. Posi, Superior Axles, 3:73 G
I was wondering if I can use a handheld vacuum pump to check if my brake booster is bad. If so, what is the usual vacuum reading as you pump, ie. max vacuum it'll hold. I did a "trial" run with it and got around 11 inches of vacuum, after many squeezes, and that was max. Any help or suggestions would be great, thanks.
