ported vacuum outlet on carburetor
Old Jun 30, 2002 | 10:19 AM
brett_sc's Avatar
Car: 86 SC
Engine: 5.0 305 LG4
Transmission: M5
Does anybody know which outlet is a "ported" vacuum outlet on an edelbrock 600. I have 3 outlets.
pass. side, middle, drivers side.
the one in the middle is too big, so it is one of the side ones.
Old Jun 30, 2002 | 10:23 AM
rjmcgee's Avatar
If ported means no vacume at idle then it is the left one. Check out their web site, they have all the info you need on it
Old Jun 30, 2002 | 10:32 AM
brett_sc's Avatar
Car: 86 SC
Engine: 5.0 305 LG4
Transmission: M5
Yes it does mean novacuum at idle. When you say left, do you mean pass. side, or driver's side??
Thanks for your help.
Old Jun 30, 2002 | 10:44 AM
rjmcgee's Avatar
passanger side, or as I like to call it left.
Old Jun 30, 2002 | 10:50 AM
brett_sc's Avatar
Car: 86 SC
Engine: 5.0 305 LG4
Transmission: M5
Thanks a lot. This tube already splits once and one tube goes to a wire harness connection next to the distributor, and the other runs deep into the uncharted areas of my wire looms.
Any ideas on if I need to keep either of those tubes, or should I just split it again??
Thanks again.
Old Jun 30, 2002 | 11:47 AM
82camaro's Avatar
Car: 82 camaro SC
Check it to be sure. Pull the line off while the car is running, ported vacuum will have no vacuum at idle.
Old Jul 1, 2002 | 11:30 AM
MIG-29's Avatar
Car: 1987 Camaro
Engine: 1986 350
Transmission: T-5 NWC
just a little hint for everybody.
the universal way of calling left or right, forward, aft, is with yourself sitting at the pilot seat, that way theres no mistake.
and the timed port (you guys got it right) is the one on the right (passenger side), the big center one is for the PCV valve and the left is the all time vacc. port. (good to set your idle mix.)
fernando.
88SS6SPEED
Nov 11, 2015 07:05 AM
sreZ28
Oct 22, 2015 08:21 AM
budowski
Carburetors
Oct 2, 2015 10:16 AM
RedLeader289
Sep 23, 2015 06:50 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
