do i have a posi?
Old Jul 1, 2002 | 09:51 PM
Camaro90RS43's Avatar
do i have a posi?
I just bought a 86 IROC does anyone know if it came with a posi or not? it's automatic and i know the gear ratio is 2:73 but i wanted to know if i had a posi. Thanks.
Old Jul 1, 2002 | 10:13 PM
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
look at the rpo's in the counsel if u see "g80" then you got it
Old Jul 2, 2002 | 12:29 AM
rjmcgee's Avatar
Powebrake it and you will also find out
Old Jul 2, 2002 | 09:34 AM
Merlin's Avatar
You might have a 2.73 or a 2.77. Check the number of bolts on the rear axle cover. 10-bolts is a Saginaw rear, 9-bolts is a Borg-Warner. The BW units were all limited slip, and the Saginaws could be either way. Check the RPO label for the G80 code, or look at the tag on the right side tube of the rear axle for the codes.
You could also remove the differential case cover, drain the oil, and look for cone clutches. Then clean out the case, install the cover and gasket, and pump in new oil. But that would be a lot like service, which is what I would do to a car that I just got.
Old Jul 3, 2002 | 12:41 PM
f-crazy's Avatar
Engine: CARBED LT4
Transmission: MK6
not trying to steal this post but what is better the BW or the saginaw...i counted the bolts on my diff cover but i cant remember what it was i know it had atleast 9 lol...i have a 3.42 and a posi
KO1
16
Oct 15, 2015 05:00 PM
92projectcamaro
Sep 29, 2015 07:07 PM
