Some weird stuff
Old Jul 2, 2002 | 04:32 PM
Zirtbow's Avatar
Some weird stuff
Ok my key is weird.. if you touch the key cylinder (where you put the key in) it will make a sound as if you left the key in.. its all pretty loose.. anyway lately i turn the key and all the lights and stuff come on but when I turn all the way.. nothing... doesn't even try.. I turn a few more times and eventually it starts... now it only takes a few tries to maybe get that going.. if I drive it around an all i probably would get it to start in a try or two.. maybe three.. but when the car has been sitting all day while at work I go out and it will take me like 5 minutes to start it.. I pump the gas.. brake.. etc.. then about 5 minutes later after turning the key and turning the key it might decide to start... i hit the steering wheel once (i was mad) and the left turn signal came on and wouldn't go off.. a few minutes later I hit it again (frustrated it wouldn't turn off) and it turned off and the car would start.. it did this same thing the day before but I didn't have to really hit the steering wheel.. instead I just pumped the gas and waited like 5 minutes... so my question is.. is my lock cylinder loose.. ignition switch?.. or can it be as bad as my starter going out?
Old Jul 2, 2002 | 06:05 PM
PonchoTA's Avatar
Maybe the main connector in the steering column is loose.
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
anesthes
Sep 30, 2015 07:48 AM
