Starter Heat Soak problems
Old Jul 3, 2002 | 10:12 AM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
Is a heat shield or starter blanket good enough to fix it or should I just buy a high torque mini starter? Or should I get both?
Old Jul 3, 2002 | 10:30 AM
ede's Avatar
ede
someone ( i think rb) the other day said heat soak = too small starter, i'd buy the mini high torque
Old Jul 3, 2002 | 11:25 AM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
A mini-starter will definatly do the trick. As far as the sheilds go, I've heard they work but never actually talked with someone who really uses one.
Oh yeah, 1 thing that I've heard is that once you start getting heat soaked issues, it will only get worse. So a sheild may work, but you'd end up replace the starter later anyways. That's just what I've heard though.
Spyder_TheGamer
Dec 25, 2015 05:07 PM
mustangman65_79
Sep 1, 2015 03:51 PM
Frismund Snoid
Aug 27, 2015 11:08 AM
92camaroJoe
Aug 13, 2015 06:07 AM
