What's this wire near the knock sensor?
Old Jul 4, 2002 | 09:07 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Here's a pic of the wire that's in the same section of the harness loom as the knock sensor wire. Somebody suggested before that it may go on the starter, but I don't think that's the case. This isn't a stock ring terminal. It's one that somebody added. The wire is all black. I'm guessing it's a ground. I checked the GTA, but that's got the newer integrated harness, so I got nowhere.
Copy and paste this into your browser:
http://iroc.fbody.com/knock_plug.jpg
Anybody with an 86 or 87 know what this is? My 85 harness didn't have it, and my 88 harness is integrated and I couldn't find anything similar in that area.
Old Jul 4, 2002 | 11:17 AM
ede's Avatar
ede
i couldn't get the pic to load, i'd guess it's a ground that should be screwed to the frame or body soemwhere close by
Old Jul 4, 2002 | 01:28 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Here's his picture for people that are too lazy to copy and paste.
I don't know what that wire is either. Looks like a ground.
Old Jul 4, 2002 | 07:03 PM
Jim85IROC's Avatar
Well, I did a continuity check between the + battery terminal and this wire, and it had continuity. Looks like it's a +12 wire. It must go on the starters on the 87s, but I have no idea why. I taped it off and wire tied it out of the way.
Old Jul 4, 2002 | 07:14 PM
goneracin's Avatar
My 87 has the same wire, although someone prior to me has cut and taped the end. I was and still am wondering what it is.
Old Jul 4, 2002 | 10:49 PM
firbird's Avatar
i believe its the wire that hooks to the starter, the starter should have two terminals one were all the hot wires go like the ones with the fusible links and another quite small wire that looks very similar from the pic i saw that goes on a small post on it. Is your car running? If it’s running without it i might say it’s not the wire to your starter though.
Old Jul 5, 2002 | 09:20 AM
goneracin's Avatar
yes, it runs fine without it hooked up. I thought it went to the starter also, but im afraid to hook it to anything, as everything works currently.
Old Jul 5, 2002 | 09:22 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Looks kind of like something somebody added, for an accessory like a stereo or somthing like that.
Old Jul 5, 2002 | 09:47 AM
leirch's Avatar
I had my 87's harness gutted last winter to remove 165 ecm relay wiring and various other wiring to convert it to a 730 harness completely and I noticed that wire, it connected to the starter, I can't remember where it goes, maybe its for a fan relay? Second fan maybe? I'm not real sure though, I'm at work and don't have the wiring diagraphms handy..
Brendan
Old Jul 6, 2002 | 07:10 AM
ops32's Avatar
Car: 1983 25th Anny Daytona 500 T/A
Engine: Stock...inoperative... 305
Transmission: Automatic
If you connected the meter/light between the positive terminal and the wire, and it showed continuity... wouldn't that mean that wire is a ground?
Rob
Caspar
Jun 19, 2016 11:19 PM
bamaboy0323
Sep 3, 2015 06:07 AM
db057
Aug 22, 2015 08:17 PM
gwade12
Aug 8, 2015 08:17 AM
