Top end rebuild
Old Jul 5, 2002 | 06:53 PM
86305's Avatar
Top end rebuild
Ok it's about time for me to do something about the old 305's smoking problem. In the next 2 or 3 weeks i'm rebuilding the top end. New cam, lifters' springs, valve seals i geuss valves if it needs it, push rods, and timing chain. I geuss thats it. I plan on doing the valve seals and springs and stuff my self. Exactly how much trouble is it to remove the springs and install new seals. I know i need a valve spring compressor but what else do i need. And i need a set of good seals. Should i go with stock seals? I've heard people talk about teflon seals or something.
Never done any type of work to heads before so any help will be appreciated.
Old Jul 5, 2002 | 07:06 PM
ede's Avatar
ede
i like the fel pro positive seal and the o ring seal both. i use a piece of 3/4" pipe with a cap screwed on it to take heads apart, just set it over the retainer and smack it with a BFH. you don't need new push rods unless you're going longer than stock or have damaged ones. replace the factory rotators with aftermarket retainers.
Old Jul 5, 2002 | 09:34 PM
86305's Avatar
Can u get me some part numbers. I would really appreciate it.
Thanks for the info.
hectre13
Dec 11, 2023 08:14 AM
SiCkRs
Members Camaros
32
Jul 1, 2018 04:53 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
86White_T/A305
Aug 17, 2015 12:16 AM
sreZ28
Aug 14, 2015 07:48 PM
