car starts then dies when hot...
Old Jul 5, 2002 | 08:41 PM
t-rally's Avatar
The car starts fine when cold. But when the engine is warm(hot) it will crank fire but then the rpms will drop all the way to 0, sometimes it will stay there sometimes it will rough idle around 400. After giving the car some gas it will then idle normally around 500-600. I know this is common but i want to be as specific as possible when i try to fix this.
p.s. it didnt start doing this until after i installed aluminum ducting ram-air, perhaps i knocked a vacuum line loose?
Old Jul 6, 2002 | 07:25 AM
Vader's Avatar
Check for vacuum leaks, a sticking EGR, or TPS/minimum air adjustment. Is it TBI or TPI?
Old Jul 6, 2002 | 12:42 PM
t-rally's Avatar
its a tbi
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
killer777
Aug 8, 2015 02:47 PM
