How do you assemble/disassemble heads?
Old Jul 6, 2002 | 09:47 AM
JuGrNuT350's Avatar
Pretty much what the topic says, but how do you assemble/disassemble cylinder heads, I really new to this & need the steps & tools required to take a pair of heads apart & put them back together.
Thanks,
-Timbo-
Old Jul 6, 2002 | 10:52 AM
bob8748's Avatar
The only special tool you need is a valve spring compresser. Not expensive. I have used 2 boxed end wrenches to do this but not recommended. Have someone experienced with you, not a good place for mistakes. Simply compress the valve spring and remove the keepers. Slowly release the spring pressure and it all comes apart. Installation is the same way in reverse. Why are you taking them apart?
Bob
Old Jul 6, 2002 | 11:16 AM
ede's Avatar
ede
lot faster to use an old deep socket to take them apart, or like me, i use a 3/4" nipple with a cap, and a BFH and the keepers come right off. takes a minute or less to have them apart. you need the compressor to get them back together, and if you want to measure or blueprint anything you'd need a snap gauge and mike or caliper.
Old Jul 6, 2002 | 06:51 PM
JuGrNuT350's Avatar
I'm getting some used L98s from a guy & having them cleaned, & magnafluxed then sending them to a member on thirdgen,
rhuarc30, to port & polish them. Sounds pretty easy, I'll get my buddy to get a spring compressor from O'Reilly & we'll do them.
Thanks,
-Timbo-
Old Jul 7, 2002 | 08:43 AM
bob8748's Avatar
just remember to put the valves back in the same holes you took them out of
Old Jul 7, 2002 | 10:29 AM
ede's Avatar
ede
i've had well over a hundred heads apart and never worried about sticking the valves back i nthe same holes, other than intake or exhaust, never hada problem.
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
FormulasOnly
Sep 6, 2015 10:42 AM
z28guy134
Sep 1, 2015 11:50 PM
