Just replaced rear main seal; still have an oil leak
Old Jul 6, 2002 | 11:22 PM
cort351w's Avatar
There is oil coming from the bottom of my bellhousing and that semi-circular plate that attaches to the bellhousing. Within 6 hours of parking my car, there is a quarter-sized puddle of oil on the garage floor.
The problem is that I replaced the rear main seal Friday to fix the leak! I have a brand new Fel-Pro seal in there and the leaking continues. The two semi-circular gaskets behind the rear main seal (I don't know their names) were not leaking. My oil pan is dry so I don't think that the pan gasket is leaking.
Anyone have any ideas on what is causing this leak?
Old Jul 6, 2002 | 11:25 PM
cort351w's Avatar
I did just switch to Mobil 1 15W50 from regular 10W30 last oil change. This is stretching it because I just put the new seal in, but should I maybe wait a couple oil changes to do something, hoping that the leak will disappear?
Old Jul 7, 2002 | 05:39 AM
ede's Avatar
ede
you sure it's not the oil sender leaking, intake, or a valve cover? all would drip and run down the back of the engine.
Old Jul 7, 2002 | 08:01 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
another check....distributor..
Old Jul 7, 2002 | 10:09 AM
BOTTLEDZ28's Avatar
Transmission: A4
clean off all the oil on the engine and oi pan and then run it again watch for leaks. i sesond al the other problem areas mentioned above.
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Reborn756
Sep 4, 2015 03:42 AM
wayshegoes
Aug 17, 2015 12:00 PM
Exxon Limited
Aug 9, 2015 08:13 PM
drathaar907
Aug 6, 2015 04:20 PM
