2 out of 6 not firing
Old Jul 7, 2002 | 09:55 PM
chiefz28's Avatar
This isn't a third gen but I think it is similar.My dad has a 92 Buick with a 3.8 TPI.It started missing so the checked for spark.4 of them had real good spark while the other 2 had nothing.So they figured the coil.so they got a new coil pack nothing changed.This has the Magnavox style not the Delco.I guess there's like 2 or 3 pieces to thi coil setup.He was going t go buy the other pieceof the coil and try it but hate to buy another electric part that can't be returned.does anyone have any experience with these things and could shade some light I'd bevery greatful
Old Jul 8, 2002 | 12:30 AM
Buck268's Avatar
Since its only 2 plugs, and not all, i'd check the cap and wires...
Old Jul 8, 2002 | 10:15 PM
chiefz28's Avatar
This car doesn't have a distributor.Will check wire though
Old Jul 8, 2002 | 11:41 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
are two of the wires on the same power block thingy they have to generate the spark? One of the coils could be bad. Opps... didnt see above Maybe the circuite in the ecm that drives the coils has a problem. I had a olds. that had the same system but its been a real long time since i worked on it. Check teh connection at the base of the power block to see if all the contacts are solid.
Old Jul 9, 2002 | 11:56 PM
jester111's Avatar
hey
swap the bad coil for a known good coil and see if it works if it doesnt then it will be the modual that is bad
hope this helps
Old Jul 10, 2002 | 10:50 AM
Vader's Avatar
Chief,
That's not uncommong on the one gallon Buick engines. There should be more than one coil pack, however. Check these past threads:
https://www.thirdgen.org/techbb2/sho...threadid=91195
https://www.thirdgen.org/techbb2/sho...threadid=20430
...and this non-TGO thread:
http://www.motorage.com/edindex/099742.htm
KCG
Jun 24, 2020 04:33 AM
RS Reaper
Oct 17, 2018 07:52 PM
Giocio
Oct 1, 2015 12:20 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
indygene
Sep 26, 2015 11:21 AM
