smoke
Old Jul 7, 2002 | 10:15 PM
brihoop's Avatar
smoke
ok... heres the deal... everytime i start my car after it has been sitting for a couple of hours, a huge cloud of white smoke comes out the exhaust, but if it is only sitting for like 20 minutes it doesnt do it. anyone know why it does it and how to fix it?
Old Jul 7, 2002 | 10:34 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
are you loosing any coolant? Sounds like a blown head gasket.
Old Jul 7, 2002 | 11:53 PM
brihoop's Avatar
im not sure if i am losing coolant..i cant check right now, but how do you check if you have a blown head gasket? and if thats what it is, how much will it cost to fix?
Old Jul 8, 2002 | 01:53 PM
rezinn's Avatar
Does the smoke have a blue tint? It may just be oil from your valve seals. A blown head gasket may leak coolant into the combustion chamber, in that case your coolant level will be low, you'll get white smoke from your exhaust that smells sweet, and the combustion chambers which coolant is leaking into will be very clean, especially the spark plug in them.
A head gasket just separates the cylinder heads from the block, there are two of them in a V engine. Only coolant flows through ports in the gasket through the head and block, not oil. Since there is a large amount of labor in replacing a head gasket(removing the accessories, draining the cooling system, removing part of the exhaust, removing the cylinder heads), it can be quite expensive. You could probably remove your heads and have them rebuilt and ported, and buy yourself some decent tools to put them back on for the cost of labor alone.
FormulasOnly
Jul 23, 2018 08:47 AM
86White_T/A305
Mar 6, 2016 01:48 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
KCG
Sep 23, 2015 09:05 AM
Accerrito22
Sep 5, 2015 09:34 PM
