Scared of engine fire- replace hose to braided?
Old Jul 10, 2002 | 03:10 AM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
Transmission: T5 Manual
All it takes is a hairline fracture to our fuel line near the hot headers and bye bye car I'm getting paranoid as rubber deteriorates over time. Is braided the best way to go? Is it a good idea?
Thanks,
Felix
Old Jul 10, 2002 | 06:00 AM
ede's Avatar
ede
it fails too, but it's a lot more reliable. if you want to be safe you should inspect and/or replace the fuel lines, just like a lot of other parts on your car
Old Jul 10, 2002 | 10:25 AM
Vader's Avatar
ZZ4,
As a reference, the factory fuel supply and return lines are a two-wire braid reinforced design. They just don't have the braided outer covering. Coverings like that are really only good for abrasion resistance, and do very little to reinforce the sealing properties of the hose itself. The factory hoses have an overall rubber covering to improve the appearance, act as a secondary barrier, and provide a surface for the identification marks. Any additional overbraid will still allow the fuel to leak through if the hose fails.
If you're truly concerned about the condition of your hoses, route them away from your headers or use heat shields. If they are deteriorating, replace them with the original type.
Take a close look at 10,000 PSI WP hydraulic hoses, and they generally don't have a braided outer covering, either. That's an antiquated theory that some people may think looks cool, but serves no real purpose other than to add weight.
Old Jul 10, 2002 | 10:41 AM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
Gentlemen I think I shall be getting some heat shield and use it on the brake lines too. Unless of course I ran a larger hose over the fuel hose in its entirety. I think perhaps that it is a little paranoid though
Excellent advise, thanks. To get the mighty Vader to reply to my humble post too- I am honoured.
Felix
Frozer!!!
Jan 19, 2024 04:55 PM
dutch930
Sep 11, 2015 06:58 AM
TheExaminer
Aug 26, 2015 04:59 PM
lakeffect2
Aug 23, 2015 08:44 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
