wot fuel pressure
Old Jul 12, 2002 | 09:49 AM
posi's Avatar
wot fuel pressure
new member have question how much does fuel pressure increase under wot,have trickflow heads 24pound svo injectors hooker heades,3200stall performance built trans compcams camshaft 220/230dur 510/510 114 lob sep paxtonsupercharger highout impeller 10psi boost because when at full throtte fuel only increase from idle 46psi to about 50psi should it be higher power adder did not help also installed www.racetronix.com walbroGss340m fuel pump with hotwire kit installed could regulator be bad
MustangBeater20
Oct 29, 2022 09:20 PM
mdtoren
Aug 23, 2015 12:52 PM
R3500
Aug 17, 2015 12:16 PM
mdtoren
Aug 16, 2015 05:45 PM
Kaweh
Aug 9, 2015 02:54 PM
