comp cam on 86 305 tpi
Old Jul 15, 2002 | 02:28 PM
SMOKEN's Avatar
guys that changed from the peanut cam. how much hp would i gain from this cam comp 212/218 449/456 all i did was put a chip in the car and changed the gears to 3.42 , the car only has 25000 miles on the engine
thanks
Old Jul 15, 2002 | 03:21 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Re: comp cam on 86 305 tpi
thanks
About 35 hp or so. It is a good choice when combined with 3.42 gears
Old Jul 15, 2002 | 06:48 PM
SMOKEN's Avatar
thanks for your comment i hope to see that 35 ponies
Old Jul 15, 2002 | 07:51 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Is that a custom eprom or just some crap like a Hypetech, Jet or ADS?
Cams by themselves don't do much on TPI engines. You really need to address the intake, heads and eprom before you even sniff at the cam. I've seen enough guys who've added cams etc, and NEVER realized the true potential of the modification until they modified the TPI intake (the biggest strangler of your motor), followed by the heads.
When GM produced these cars, they made an engine where the intake, heads and cam were closely matched to each other and unless you do all three (and and eprom), it just doesn't perform well.
PS: How do you plan to install the cam? If you plan to just "pry" the oil pan so you can pull the timing cover off, be prepared for an "oil leaker". The best way to do it TO AVOID oil leaks is by either pulling the engine or raising it so you drop the oil pan.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
gta90
Sep 15, 2015 04:00 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
