help help help help, help help help help
Old Jul 17, 2002 | 12:18 PM
chuck6860's Avatar
Still having the same problem, and i'm just about ready to give up.
here is where i'm at,
i've taken the starter to autozone to have it tested, and it's SUPPOSEDLY good,
i've done the same with the battery,
i changed the ignition switch on the steering column,
changed the battery posts.
The car gets power, lights come on, makes the buzzing when i turn the key , but when i try to start it, NOTHING, no clicking, not a damn thing,
i'm fresh out of ideas, does ANYBODY have any clues, suggestions or ideas????
Old Jul 17, 2002 | 12:39 PM
ede's Avatar
ede
have you checked for power to the starter? park or clutch safety switch?
Old Jul 17, 2002 | 01:17 PM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
I agree with Ede, check the park or clutch safety switch. If this isn't working properly, you'll get power to everything like normal but the starter will not even attempt to crank because the system "thinks" your in gear.
Do you have an auto or manual tranny?
Old Jul 17, 2002 | 01:28 PM
chuck6860's Avatar
I have an automatic tranny, how do you check the park or clutch safety switch?
Old Jul 17, 2002 | 01:29 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
If you have an auto transmission put the car in N and see if it starts. The neutral safety switch should allow it to start in N if that’s the problem. I would also check to see if the battery cables are good. The cables can get burnt internally and will not feed enough juice to the starter.
Old Jul 17, 2002 | 01:31 PM
chuck6860's Avatar
sweeet,,, will do just that, if it doesn't start in neutral and the battery cable is replaced, then what?
Old Jul 17, 2002 | 05:41 PM
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
did u check the alternator?
Old Jul 22, 2002 | 01:22 PM
chuck6860's Avatar
no, hadn't checked the alternator, i figgered the problem was not in the charging system,, YET, since i couldn't get the starting system to work correctly, but i'm not ruling that out either, thanks!
Old Jul 22, 2002 | 01:50 PM
CraZ-28's Avatar
Car: 1991 Z-28
I'm probably going to sound like a moron for saying this but have you checked all the fuses yet? I had something similar to this and all it was, was a damn fuse.
Good luck.
Old Jul 22, 2002 | 01:52 PM
wiggy'sIROC's Avatar
Car: 1986 IROC
Engine: 305 going to 355
Did the car ever have an alarm system on it with a starter interupt relay? I recall there is a guy around here that had a similar problem and that is what it turned out to be.
Mark
Old Jul 22, 2002 | 02:25 PM
chuck6860's Avatar
any suggestion is golden to me at this time, i checked the fuses initially, and they seemed fine, but i'll go ahead and try that again just to be safe, in response to wiggy'sIROC , no the car never had an alarm system on it, i inherited it from a friend, i do remember having to use a screwdriver to start it in the past on the starter so i dunno, we'll trudge on and see what we can find out, i think i'm going to go ahead and yank the starter again and check all the wiring make sure it's all kosher up under there, thanks again guys!
Old Jul 22, 2002 | 04:40 PM
breathment's Avatar
Good luck.
good question. don't wanna overlook the simplest things. iv done it
Old Jul 23, 2002 | 09:36 AM
chuck6860's Avatar
good call, i'll make sure to check those can never be too careful
