Timing???? advance or retard???
Old Jul 17, 2002 | 06:11 PM
NOCANDO's Avatar
I know this may be a overheating problem, but Im thinking it has to do with the timing. Ever since I installed my open filter element and headers with a less restricted exhaust, I've noticed that my engine would overheat. I never had that problem before installing the mods. Now that my engine is breathing better, do I have to compensate with either advancing or retarding my timing. Its on 0 degree TBC now (stock)....
Old Jul 17, 2002 | 09:49 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Not sure what engine you have (year, induction type would be nice to know). But, advancing the base timing usually helps it run better. Try in 2 degree increments, starting at about 4 degrees, and back it off if it starts pinging while driving.
Old Jul 18, 2002 | 12:16 AM
NOCANDO's Avatar
Sorry....I have a stock 305 V8 TBI with a few mods...nothing more......
Old Sep 4, 2002 | 07:04 PM
homebrew's Avatar
I've had the same problem on my 350 tbi. Ever since I put on headers its been running too hot 230-240. I've raised the fuel pressure but it didnt do much. Did the timing solve your problem?
Old Sep 5, 2002 | 12:34 AM
mrbboy's Avatar
I have a 91 305 TBI and the manual says the correct timing is at 0 TDC (plus it also says that on the plate thing under the hood). My car also used to run hot but I found out it was because of a small intake manifold leak. I replaced the gasket and thermostat and did a complete tune-up and now, my car runs cool and great.
Amillionoh7
May 24, 2020 08:01 AM
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
Thirim
Aug 9, 2015 06:19 PM
djmarch
Aug 9, 2015 05:27 PM
