what engine do i have?
Old Jul 17, 2002 | 08:00 PM
Electron_Blue's Avatar
Car: 83 Camaro
Transmission: th350
a few weeks ago i bought a 83 sport coupe camaro...it orginally came with a 2bbl 6-cylinder...a few owners ago somebody dropped in a carburated v-8..the guy i bought it from said he thinks that it is a 305 but is not sure....it is probably a 305 but i dont know what its from...it has a edelbrock dual plane intake and a 1" spacer to a holley carb...i think 500 or 600...my dad said i might be able to tell by the #'s on the block but if he is correct they are in the backof the engine....if there anyway to tell....please help me out guys!!?!
Old Jul 17, 2002 | 08:06 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
The only way to tell for sure is to get the #s. They should be on the driver side of the block. If not there should be some up front.
Old Jul 17, 2002 | 08:09 PM
Car: 83 Camaro
Transmission: th350
can you kinda point out the right direction of where to look? and will it distinguish between the different types of 305's in camaros or will i have to look at the heads or something for that?
Old Jul 17, 2002 | 09:41 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Behind the driver's side head, cast on top of the bell housing casting. Nice, convienent place to look for it.
It will only tell you it's a 305, and perhaps approximately what year it was made. Part of the VIN from the original car is stamped in the S/N pad in front of the passenger side head (under the alternator - another nice place for it). Sometimes, you can glean a litte info from that.
The head casting number is under the valve cover. That might give you a little more information.
Old Jul 19, 2002 | 10:21 AM
Vader's Avatar
Maybe this will help 5-7 explain it a little more clearly:
Baaa-aaa-aahh! Just the sheep complaining...
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
