Idles drops/stalls after put into gear.
Old Jul 18, 2002 | 09:34 PM
FIRECHICKEN's Avatar
Car: '89 Formula 350
Engine: 5.7L L98 TPI
Transmission: 700-R4 Automatic
Axle/Gears: 7.5 disc posi 3.23
I have an 87 GTA. The Idle drops down low and the car bogs and runs like crap when I put the car into gear. It goes away after awhile but it does it every time I put it into any gear.
Old Jul 18, 2002 | 09:38 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Tell us everything relevent about your engine. Impossible to help otherwise
Old Jul 18, 2002 | 10:39 PM
Mo's Avatar
Mo
if its TPI, it might be a bad IAC valve. Mine would idle fine in park and nuetral, but as soon as i put it in gear it died if i didn't keep on the gas.
Old Jul 18, 2002 | 11:27 PM
1982chevycamaroz28's Avatar
my car does that when i start the engine and only let it warm forl ike a min but if i let it sit longer it will barly do that. also mine is carbed.
Old Jul 19, 2002 | 12:36 AM
Engine: 305-4v
Post this on the Carb board, those guys will have some better ideas than we do. I'd say you should adjust your idle mixture, if that is possible. You probably have a CC QJet and you can't fiddle with that, though
Have you tried turning up your idle speed? After a while every carb needs a bit of tuning up and idle speed is one of the first things to go awry.
It is adjusted by turning in the screw on the driver's side of the carb that bumps the throttle bracket open a bit. You'll see it when you look closely. It must be approached with your screwdriver from the front of the carb. Only do this after the engine is warmed up to the point that it no longer stalls. Set your idle speed to 750 - 800 rpms in park. It should drop down to around 550 - 600 rpm in drive.
If that isn't it, you may just need to rebuild the carb. It happens to ALL of us, so it isn't just you
Old Jul 20, 2002 | 08:57 PM
It is a TPI 350. It was a transplant engine from an 88 Z28.
I'm actually asking for a friend so I don't know too much.
Old Jul 20, 2002 | 11:23 PM
Engine: 305-4v
Well, TPI is a whole different kettle of fish.
Take it to the TPI board and those folks will have some good troubleshooting ideas right off the top of their heads. They're a pretty sharp bunch
junkcltr
Aug 2, 2019 11:12 PM
jklein337
Sep 19, 2018 06:23 PM
mizz0313
Aug 12, 2015 06:45 AM
