Looking for the correct 350 block
Old Jul 19, 2002 | 05:24 AM
jlamprecht's Avatar
I have an 87 305 TPI IROC-Z. I'm looking to do a 383 but I don't know what year of block to buy. I bieleve that 1987 switched from the old accessory bolt location to the new accessory bolt location. I don't know what mine is. I want to be able to use all the accessories that is on the existing motor on the new motor.
Do any of you know?
Old Jul 19, 2002 | 06:35 AM
ede's Avatar
ede
bolt holes in the block are the same as far as i know. if any accessories bolt to the block they use the bolt holes for the front style motor mounts, and that's been on them for a few years now, or the water pump has bolt holes in it.
Old Jul 19, 2002 | 07:36 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
All 350 blocks will accept all accessories. THat's not an issue. Like ede said, those bolt holes have been there for a few years now... since 1955. So make sure you get a 55-up motor.
You should be looking for a 87-up block. It will have provisions for a roller cam and will accept you current flywheel / flex plate. Ideally you'd want to find one that still has the cam & lifters still in it, so you don't have to buy new lifters; or you could re-use your existing roller lifters from your 305 in your new motor on whatever cam you end up with. Those are the issues, not bolt holes.
Old Jul 19, 2002 | 08:42 AM
jlamprecht's Avatar
Thanks for the info. Must of heard some bad info somewhere.
Jake_92RS
Jan 28, 2020 10:37 PM
theshackle
Mar 5, 2017 06:37 PM
Reborn756
Sep 4, 2015 03:42 AM
lakeffect2
Aug 23, 2015 08:44 AM
BBSDesigns
Aug 11, 2015 07:39 PM
