replaced wires....not hesitates and slight miss......help please
Old Jul 20, 2002 | 10:23 PM
83CAMAROMAN's Avatar
Car: 1983 Camaro Sport Coupe
Engine: 1986 305 C.I.D. Bored .030 over
Transmission: TH350 W/Shift Kit
Axle/Gears: 3:08
Hey guys.....first of all thanks for taking the time to read this...
1983 camaro....305 bored .030 over....hei ignition....no emissions
i replaced the plug wires today...i had a set of those cut to length ones b4 but decided to just buy the stock replacement set of bosch wires(8mm) when i was trying to best match up which wire lenght went to which plug(one at a time not to mess up order) i wound up using the shorter ones all on the passenger side. i didnt think this would be a problem but when i started the car and went to go....there is a hesitation like a slight miss.....its not major but it is def noticeable...i checked all the wires and they are on the plugs/dist correct....(heard and felt the "click" when i pressed em on) as a matter of a fact ive checked it three times....the wires arent crossed because i never had more than one off at any time.....
the question i have is this: could the use of the shorter wires all on the one sidehave anything to do with this?
also.....on my alternator....i noticed(dont know if i did it during install of wires or not) that the orange wire coming off the back of the alt is not connected to anything.......what does this wire do...and where should it go and furthermore could THAT have anything to do with the above problem....
i need any advice possible...i drive 35 miles each way to work each day and dont want to run the car too long like it is.....
thanks in advance
Old Jul 21, 2002 | 01:20 AM
89WS-6's Avatar
I dont know what your problem is man, but I dont think it could be the shorter wire problem. Check your timing, it is possible you could have rotated the distributor a very slight amount, and it doesn't like it....
Old Jul 21, 2002 | 02:57 AM
kevinc's Avatar
Car: 1982 Z28
Sounds like you messed up the firing order. Start at plug 1 and recheck.
Old Jul 21, 2002 | 07:23 AM
Axle/Gears: 3:08
already checked that.....plus like i said..........i neverhad more than one plug off at a time........any other ideas.....im stumped.....
ill be checking the timeing today after work.......maybe thats what i did
Old Jul 21, 2002 | 03:19 PM
Axle/Gears: 3:08
ok i checked the timing.....everything is fine except for the hesitation.....i dont know what to do......does that orange wire from the alt mean anthing that would cause this.....i looks like a clean cut and there isnt any other wire that i can see to attatch i to...........
please help....thanks
Old Jul 22, 2002 | 02:27 PM
Axle/Gears: 3:08
just an update....it was a seperated wire....inside the boot......lol im so relieved
db057
Aug 22, 2015 08:17 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Armored91Camaro
Aug 12, 2015 09:41 AM
