Do I need a tranny cooler since I installed a 3,000 stall converter??engine runs hot
Old Jul 21, 2002 | 06:31 AM
ChrisFormula355's Avatar
Car: Junk
Engine: Junk with nitrous
Transmission: Junk with gears
I put in a 3,000 stall converter into my girlfriend camaro, along with the higher compression motor, and it seems to be heating up big time because of it. What exactly are you supposed to do when you have a high stall converter in a car? Is the factory radiators tranny cooler insufficient? This is a 10 inch converter so it really DOES stall at 3,000 rpms and feels really slushy unless your'e above about 3,200 rpms or so. I'd imagine that builds a bit of heat. Trying to solve an engine over heating problem.......my guess is the tranny fluid may be overly heating up the coolant........but I've heard its usually the opposite that is true.....????
Old Jul 21, 2002 | 06:56 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
You definitely need a trans fluid cooler. When the converter is "slipping", i.e. below its stall speed, it's just like a mechanical clutch that slips; and all the heat that is generated goes into the fluid. YOu stock trans cooler is in the "cool" side of the radiator. SO what happens is that the coolant flows through the rad, gets cooled, and then gets heated back up again before it gets back into the motor, so it's already too hot.
Try a trans cooler, it may or may not solve your problem, but the car needs one regardless.
Old Jul 21, 2002 | 09:27 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
Yep, definatly need a cooler! Like this beauty Supercooler on Ebay (uhhumm.. uhhmmm...)
But anyway, there's two other things that are making heat. More horsepower and more cruise RPM so a bigger radiator may be needed... Start with the lower air deflector, if it's missing get a new one... It really does make a difference. Then maybe a lower temp fan switch could help....
Good luck..
Old Jul 22, 2002 | 07:57 PM
gtabadboy's Avatar
Get a race supercooler by B&M. They are only 60 bux plus hose and fittings at summit. I just got one for my tranny and Im running a TCI super street fighter that stalls between 3400-3600
Old Jul 22, 2002 | 08:35 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Any converter with a stall higher than stock should have an external cooler installed. Heat is the biggest killer of trannys. Without a tranny temp gauge you have no way of telling just how hot the tranny fluid is getting. Above 230* and the seals start cooking. The tranny temp should be around the same temp as the engine. 180-200* is prefered.
My 8" converter in the race car generates an enormous amount of heat. I have a huge cooler in front of the rad and after a 1/4 mile pass the temp is up to 220*. The converter also stalls at 5000+ rpm.
theshackle
Mar 5, 2017 06:37 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
Jae992
Aug 27, 2015 09:07 AM
TreDeClaw
Aug 14, 2015 06:58 PM
camaroken83
Aug 10, 2015 11:35 AM
