Can someone with Desktop Dyno run this combo for me?
Old Jul 23, 2002 | 12:46 AM
Nate2's Avatar
I'm not sure exactly what variables Desktop Dyno needs, but here is everything I could concieve being needed.
3.562" stroke x 4.030" bore(363cid)
5.700" rod
1.519" piston compression height
Total Seal gapless ring set
10.5:1 compression
Vortec L31 heads
Comp Cams Magnum 294S camshaft
Comp Cams Magnum 1.6:1 rocker arms
Edelbrock RPM Air-Gap intake
Holley 750 CFM 4150 carburetor
1.625" Hooker Super Competition headers
Moroso 8.25" deep 7 quart oil pan with built in scaper and windage tray
I'm probably going to do a gasket match to the intake and heads while also dropping in 2.02/1.60 valves in. The press-in studs will be converted to screw-in types and it will have dual valve springs in the 1.46" range. I hope all of that helps, if there is anything else you need, tell me. I really need to get Desktop Dyno...
Old Jul 23, 2002 | 01:47 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
I come up with 465 HP at 6000 RPMs, and 470 TQ at 4500 RPMs.
Old Jul 23, 2002 | 03:10 AM
Nate2's Avatar
Not bad.
Old Jul 23, 2002 | 03:41 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
I ran your design through Engine Analyzer allowing
a conservetive head spec of 232 cfm@.500" in and 180cfm@.450"ex for your warmed over vortecs. with 2.02'sx 1.60's. You can exeed this easily, but will give you an idea.
I got 482hp@ 6500 rpm and 451 ft/lbs@4500.
I ran it with stock out of the box vortecs and got
460hp.
This would be under ideal conditions with no accessories on the motor to rob power. Your mileage will vary.
The real power of these dyno simulation programs is not the absolute numbers but the trends that occur when you compare
different parts. Take it with a grain of salt.
Old Jul 23, 2002 | 02:10 PM
Nate2's Avatar
Yeah, Desktop Dyno has been known to be a little generous.
The only accessories I'm going to run are a water pump and an alternator, no power steering or air conditioning. I'm not sure how much power that would drain, but 20 sounds about right.
MustangBeater20
Oct 29, 2022 09:20 PM
1984HO
Mar 19, 2021 11:59 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Fast355
Dec 2, 2016 06:33 PM
Reborn756
Sep 4, 2015 03:42 AM
