Harmonic Removal
Old Jul 23, 2002 | 05:05 PM
82resto's Avatar
Harmonic Removal
I need to remove the harmonic balancer on my GTA... any advice on how to make the job easy?
Jon
Old Jul 23, 2002 | 05:08 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Get a harmonic balancer puller.
Auto Zone, CSK, Advance, etc. all "rent" them for free.
Old Jul 23, 2002 | 06:40 PM
brett_sc's Avatar
Car: 86 SC
Engine: 5.0 305 LG4
Transmission: M5
While you're there, make sure that they give you all of the parts. Look at the ones on the shelf to make sure if you don't know what is included. Do not screw that bolt into the crank snout without the "center ****?" pinted tip thingy. The auto stores tend to leave that part out sometimes.
This will force you to have to re-tap the crank.
Also, when you return the Harmonic Balancer puller, rent a Balance installer. It makes installing the balancer as easy a job as the puller does for removing it!
Hope that helps.
Old Jul 24, 2002 | 02:21 PM
82resto's Avatar
Hey, thanks a lot, that's what i needed to know.
Later guys
Jon
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
ctoledo0834
Sep 18, 2015 04:16 PM
Magman
Sep 13, 2015 12:14 AM
Stroopwafel
Sep 11, 2015 06:38 AM
