Oil Pressure
Car: 85 Trans Am
Engine: LB9
Transmission: Finally Fixed (T5)
Oil Pressure
Okay, here is the problem....last night, I was comming home and as I went over a speed bump, I heard a pop.
I then looked down, and my oil pressure gauge (normally reads 30 or so at idle) was down in the red at idle. If i gave the car a little gas, the oil pressure would build to about 30 again, but I did not give it much gas. I just changed my oil this weekend to Castrol Syntec 10W30, don't know what was in it before. The car is a 1985 Trans Am with a stock 305 TPI with 92k miles and an automatic. And before you ask, I was crawling over the speed bump. I drove the car the 100 yard to my house, let it cool down some and checked the oil, and the level was still full. I restarted it to move it into the garage and it had about 15 psi, at high idle, on the gauge. Any help on this would be appreciated.
Car: 85 Trans Am
Engine: LB9
I haven't gotten a chance to crawl under the 'bird yet. I am going to be doing that this weekend, and hooking up the pressure gauge. Thanks
