Pictures of one and two piece rear main seals?
Old Jul 24, 2002 | 08:40 PM
GilmourD's Avatar
I have a 350 block that's supposed to be from 1988, but it also has non-roller cam and lifters... Could somebody post pics of the differences between the rear main seals?
Old Jul 24, 2002 | 11:35 PM
PLANT PROTECTION's Avatar
Car: 1987 Monte Carlo SS
Transmission: 200-4R
Axle/Gears: 7.625 10 bolt/3.73s
Check the casting numbers here: http://www.mortec.com/castnum.htm
Old Jul 25, 2002 | 01:14 AM
rezinn's Avatar
I'm pretty sure that a lot of trucks had flat tappet cams well after the change to roller in fbodies, so it could be from that year.
Old Jul 25, 2002 | 07:23 AM
GilmourD's Avatar
So, the cam and lifters that I have that would work for a pre 87 (non-roller) block should work 100% fine, right?
Old Jul 25, 2002 | 09:29 AM
ede's Avatar
ede
you can use a flat cam in a roller bolck, you just need the cam, lifters, push rods, and differant gear set and timing chain, and trash the roller cam retainer
Old Jul 25, 2002 | 08:47 PM
GilmourD's Avatar
I thought that the lifter bores in a roller block were a different size. Also, I didn't see a retainer inside the block. And everything else should be fine if I bought it for a non-roller block, right? I was originally building up my 305 LG4 with CFI heads, but I borked the crank and rods somehow and it would've cost as much to cut the crank and do the rods up as to buy this whole350 engine ($300 for a 2 bolt engine with everything 'cept waterpump, flywheel, and intake). Since one of the valves on the 350 heads seems to be stuck open, I'm gonna run the car with the CFI heads (I know, I know!!! ) for a while, redo the 350 heads, sell them, and get myself the Vortec iron heads and the matching intake. :rockon: :hail:
Old Jul 26, 2002 | 06:38 PM
GilmourD's Avatar
ttt
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
Reddeath210
Oct 6, 2015 08:20 AM
Reborn756
Sep 4, 2015 03:42 AM
86White_T/A305
Aug 17, 2015 12:16 AM
