Missing IROC
Old Jul 25, 2002 | 06:54 PM
QuietBob's Avatar
Car: 1987 Camaro IROCZ/28
Engine: TPI 383"
Transmission: TH 350
Axle/Gears: 10 bolt 3:27
Missing IROC
Here we go again! '87 IROCZ/28, TPI350, TH350, bone stock. The car begins missing AFTER it reaches operating temperature, and then only at 1/2 throttle or more. At WOT, it's worse. At 1/4 throttle or so, everything is fine. It's good at 80 mph as long as I don't "load" the motor. WASSUPWIDDAT??
Old Jul 25, 2002 | 07:11 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Still have a cat?
Old Jul 25, 2002 | 07:33 PM
QuietBob's Avatar
Engine: TPI 383"
Yes. It has A single CAT on the passenger side of the undercarriage.
Old Jul 25, 2002 | 07:38 PM
Car: 99 Formula
Axle/Gears: 342
Make sure it's not clogged. Is your car running hot, or at nite see if it glows once the car heats up.
Old Jul 25, 2002 | 09:21 PM
jfox55's Avatar
How long has it been since you have changed your fuel filter???? Or maybe just a tune up.
Old Jul 25, 2002 | 09:42 PM
QuietBob's Avatar
Engine: TPI 383"
Fuel pump is 2 months old. Fuel filter is 1 month old. Tune-up was last month, with new MSD cap, rotor, wires, and Bosch plugs. How do I know if the CAT is plugged or not??
Old Jul 25, 2002 | 09:46 PM
jfox55's Avatar
Old Jul 26, 2002 | 12:48 PM
rezinn's Avatar
Your cat isn't clogged. If you haven't replaced your stock ignition coil with an msd one, you might as well. If it's been over 60k since your replaced your oxygen sensor, go ahead and do that. I was having similar problems with my car last year and after I replaced the o2 sensor, coil, plugs, filters, wires.. I replaced the entire distributor, cap and all, with an msd unit. I paid $230 and my problems went away.
Old Jul 26, 2002 | 08:11 PM
QuietBob's Avatar
Engine: TPI 383"
Thanks, guy's. In response to "rezinn", the coil has not been replaced by me, nor has the O2 sensor. Thanks for the advice. NAPA will get a visit from me in the morning. QB
Old Jul 27, 2002 | 10:28 PM
83CAMAROMAN's Avatar
Car: 1983 Camaro Sport Coupe
Engine: 1986 305 C.I.D. Bored .030 over
Transmission: TH350 W/Shift Kit
Axle/Gears: 3:08
dont forget to check those plug wires.........easy fix if they are bad......
Old Jul 28, 2002 | 04:30 AM
Odyssey's Avatar
I bet it's a fried wire. A bad 02 sensor will not make your car run bad at WOT. The ECM ignores it at WOT...
Old Jul 28, 2002 | 05:23 AM
IROC57TPI's Avatar
Bad TPS is my best educated guess. Try scanning it or if you have a digital VOM try that. Another thing is the coil could be going bad.
IrocBuzz
Camaros Wanted
Nov 20, 2015 11:29 AM
mhatfield 14
Oct 24, 2015 07:48 AM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Thornburg
Mid-West Region
Aug 25, 2015 08:20 PM
mustangman65_79
Aug 11, 2015 03:17 PM
