squeaky engine
Old Jul 27, 2002 | 10:34 AM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
squeaky engine
something's squeaking in/on/around my engine, it'll do it when the car's stopped so it's not the chasis/suspension. it's high pitched and gets faster if you rev it but i just can't pin it down and it's getting really annoying. anyone know where i should look? should i oil my accessory pullies (where the bolt is, not on the belt surface)?
Old Jul 27, 2002 | 11:35 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Try using a automotive stethoscope to pinpoint your squeak.
Old Jul 27, 2002 | 03:00 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Most of the accessories have sealed bearings, so getting oil in would be difficult.
If you have seperate belts, you could remove one at a time till the noise stops.
Old Jul 27, 2002 | 03:02 PM
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
It might be a blower!... naa... maybe just a belt.
Old Jul 27, 2002 | 03:11 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Try putting your ear up to the alternator (but not too close, if you still want to have an ear)
Old Aug 15, 2002 | 07:26 AM
Car: '87 Camaro LT
Engine: 355 L98
well i've narrowed down where the nosie is from. if i put really light pressure on the clutch pedal, like one pound/half inch of travel, it goes away. what could be making the noise down there? is it okay to block the pedal from coming up that final half inch to stop the noise?
Old Aug 15, 2002 | 07:43 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Throwout bearing.
No.
Old Aug 15, 2002 | 07:48 AM
Car: '87 Camaro LT
Engine: 355 L98
so is the bearing squeaking because it's worn out or does it just need to be greased more?
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
