EGR Problem
Old Jul 27, 2002 | 05:18 PM
Aaron's 87's Avatar
EGR Problem
1991 GTA - has a tip in stumble and chuggle in low-rpm/high-gear, cruise BLMs of 108. I went through all the test on everything to no avail. Even the EGR tested well according to the service manual. On a hunch, I pulled the vacuum to the EGR and plugged the hose so there was no vacuum leak. All my problems were solved.
EGR duty cycle is going to 99% as soon as I touch the throttle. I think that is normal. But, since it's a negative backpressure design, I wonder if the vacuum bleed off isn't working well. The manual says to apply vacuum to the EGR valve and start the engine - the vacuum should drop and the valve should close. Well, it does, but not instantly. So, maybe the backpressure bleed-off diaphram isn't working well?
Or, maybe the exhaust gas is somehow too rich and the slightest EGR bogs the engine?
Any ideas before I pull the plenum and throw on a new EGR? BTW, I took out most of the EGR wall in the plenum and the exhaust is catless with a flowmaster.
Old Jul 29, 2002 | 09:28 AM
Aaron's 87's Avatar
TTT
Old Jul 30, 2002 | 02:57 PM
Aaron's 87's Avatar
try again
Ghettobird52
Jul 5, 2024 11:18 PM
db057
Sep 4, 2015 07:57 AM
dyeager535
Aug 28, 2015 08:10 AM
mustangman65_79
Aug 8, 2015 12:07 PM
