Attn: 383 Builders
Old Jul 27, 2002 | 10:01 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Attn: 383 Builders
What cam did you choose and why?
My 383 project has come to a halt untill I select a cam.
I got the clearance work done to the bottom end and I need to send block back to the machine shop for the final dip and cam bearings, but I need to check rod/cam clearance first.
Thx!!
Old Jul 28, 2002 | 08:08 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
ttt
Old Jul 28, 2002 | 08:17 PM
BumpaD82's Avatar
Car: 1982 Z28 & 1967 RS & 2002 Z28
Engine: 388 ci SB / 454 ci BB / LS1
Transmission: 4 speed / TH350 / T56
Axle/Gears: '91 "1LE" rear, posi w/ 3.23's
Comp Cams XE268H
477/480....
Good "bigger" cam with noticeable idle, but enough to be liveable with power brakes and street driven in a 4 speed car....
LOT OF TORQUE
a 272 WOULD HAVE BEEN TO BIG for my application (388 = 4.060 * 3.750 )
Attached Thumbnails Attn: 383 Builders-82-383-stand-small.jpg
Old Jul 29, 2002 | 08:52 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Thx for the input!
I was looking at that cam except in a hyd roller model.
Right now it's a toss up between the Comp cams and a Lingenfelter (LPE) cam. I'm wanting to get over 400 lbs of torque before 2000 RPM. With a lobe seperation of 112*, relatively short duration (211-213*) and a .530-.560" lift, the LPE 74211 is looking pretty good.
Anyone else with a 383 cam??
Thx!
BTW BumpaD82, eng looks nice!!
Wish i was that far along w/mine..
Old Jul 29, 2002 | 09:02 PM
gtabadboy's Avatar
Got the Lunati roller cam P/N 50169. See sig for other specs. Dur at .05 248/252, lift .606/.585
Old Jul 30, 2002 | 01:09 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
The LPE 219 cam is a better one than the 211. I had that cam in my 383 with SR, and it ran good.
New cam is custom comp hyd roller 230-236 dur .603-.608 lift 114 lsa.
Old Jul 30, 2002 | 03:29 PM
Fast3rdGen's Avatar
my cam is a gm performance parts solid lifter cam.
.493/.512 lift 257*/269* dur. @ .050
it's quite radical sounding but has very good all around power and i don't mind driving it at all on the street.
Old Jul 30, 2002 | 08:03 PM
MightyMouse's Avatar
Car: 90 RS
Engine: 383
Axle/Gears: 3:23
I am starting off with a zz4 cam. It is small for a 383 but it should work good with a less than perfect exhaust system. I dont race my car I just want more power.
Old Jul 30, 2002 | 08:16 PM
jamesbern's Avatar
G.M. Hotcam and it runs very well great low end torque and ends around 6000, perfect for the street. Check out last months Chevy High Performance for dyno figures with Vortech heads.
Old Jun 22, 2005 | 06:57 PM
BrandenCali's Avatar
So how did you do?
Old Jun 22, 2005 | 07:21 PM
TWICEtheRICE's Avatar
Car: 91' Pontiac Firebird
Engine: 388 ci Small block CHEVY (4.060x3.75), Dart Iron Eagle Platinum 200cc, Performer intake, 454 TBI, Long Tubes, True Dual 3" GPs
Transmission: 700R4, B&M, Governer Recal, 20,000 GVW cooler
If you are using HiPo H-beam rods than you shouldn't have an issue with rod/cam clearance.
If you are worried about it get your specs for your cam and call up the manufacturer and get the part numbers for a "Small Base Circle" Camshaft.
I ran into a rod/cam clearance issue, so I purchased a small base circle cam and at timing nothing touches.
Also, don't balance your stuff until you have clearanced the pistons-to-counterweight and the rod bolts if you have to clearance them.
Old Jun 24, 2005 | 10:13 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
219 cam here.
Old Jun 25, 2005 | 12:07 PM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
Axle/Gears: 9 bolt 3.27 posi
comp xe274,used it in the 355 and if the extra cubes of the 383 tame it just a bit,i'll be very happy!
z28venezuela
Oct 24, 2015 08:15 PM
LT1Formula
Oct 8, 2015 08:34 PM
