for the love of G0D help!!! BIG problem with keys.
Old Jul 28, 2002 | 02:41 PM
mattRS's Avatar
i was going down a road todya, when a friend of mine next to me rear ended someone. i stopped, helped, and was going back to my car, when half of my ignition key broke off!!!
i had to get the damn thing towed because it wouldnt engage into anything besides park and the column was locked. is there any way i cna hotwire it? will one of the lock kits at o'reillys or autozone work?
HELP ME!!!!!
Old Jul 28, 2002 | 03:14 PM
darbleinad's Avatar
Car: 84 Trans Am
where did the key break? did it break in half inside the ignition?
or did it break in half before you put it in the ignition?
if so.......did it break in half, like between head of the key and the shaft with the grooves? if the shaft with the grooves on it is still intact, take this section to a place that cuts keys and have them try to cut you a new key (make sure you know the letter of the blank..ie..A,C,etc). i work at a hardware store and i cut keys and a guy came in with just the shank of his key and i was able to make a copy for him from the shank and it worked. it saved him alot of time and money.
anyway..thats just a thought
Old Jul 28, 2002 | 03:23 PM
Brett H. - 89GTA's Avatar
Car: 1989 GTA
Engine: 5.7L
Axle/Gears: 3.27 BW 9-bolt
If worst comes to worst you can always replace the lock cylinder. It's pretty easy...I had to do it when my VATS went out. Get a steering wheel puller and lock plate depressor and you're set.
Old Jul 28, 2002 | 05:02 PM
mattRS's Avatar
it split between the VATS chip and the end, so everything that knocks down the pins is gone. yeah i just picked up a lock cylinder, so looks like thats going to be the project of the night. how do i bypass the VATS?
lt1z350
Aug 28, 2015 05:57 AM
g.l.mos
Aug 22, 2015 12:02 AM
overdriv
Aug 20, 2015 03:52 PM
MY87LT
Aug 17, 2015 08:43 AM
sreZ28
Aug 14, 2015 07:48 PM
