Pre-'87 vs. '87-'95 Gaskets for 350?
Old Jul 28, 2002 | 05:55 PM
NSR's Avatar
NSR
What's the difference in these two types of gasket sets? Is it just the rear main seal or is there different intake gaskets for the Fuel Injection?
I need to buy gaskets for my engine, its TBI injected, but not a roller cam. I'm not sure about the rear main seal, but since I didn't pull the engine I'm not going to need the rear seal or oil pan gasket. Would the pre-'87 gasket set work? I don't see the point in paying twice as much for the '87-'95 set if the only difference is the rear main seal.
Old Jul 28, 2002 | 06:50 PM
boogie's Avatar
87 up has a full circle rear main seal, one piece pan gasket and intake gaskets with the rear ports blocked off for the tbi intake. Do not use the old style intake gaskets on your 350tbi, they will fit but it will run hot.
Lonnie
1992 Trans Am
May 10, 2023 07:19 PM
509 camaro fan
Sep 6, 2015 10:43 AM
Eric-86sc
Aug 24, 2015 09:01 PM
NinjaNife
Aug 23, 2015 11:49 AM
NWAsonoma
Aug 18, 2015 05:45 PM
