Air conditioning compressor rattle in 91 Camaro
Old Jul 28, 2002 | 11:53 PM
Kevin Johnson's Avatar
Hi,
I just bought a 91 Camaro RS with the 305 TBI. When I switch on the air conditioner a rattling noise comes from the compressor when the car is idling. The air conditioning seems to work ok but I am wondering if this rattle is common and what it might be. Thanks!
Kevin
Old Jul 28, 2002 | 11:56 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Mine rattled last year and this year--so far anyway--it hasn't!
Don't know why. It might be that you need to add some A/C lubricant to the coolant mix. They come in one pound bottles.
Old Jul 29, 2002 | 12:06 AM
So I guess (hope) it is not the "Death Rattle" of the compressor.
Thanks!
Old Jul 29, 2002 | 08:10 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Make sure all the bolts holding the compressor to the bracket are tight. Mine used to do that because one of the mounting bolts was loose, and the whole thing would rattle.
Old Jul 29, 2002 | 10:52 AM
Thanks for the suggestion about the mounting bolts. Could be that (cross my fingers). I found a couple loose bolts in other areas of the engine compartment.
Old Jul 29, 2002 | 01:54 PM
mtccl's Avatar
Main shaft bearing is going bad. If it starts squealing stop using the compressor or you're asking for a seizure followed by "black death" and a real mess.
Vintageracer
Jan 10, 2020 05:33 PM
Caspar
Jun 19, 2016 11:19 PM
jackhammer
Aug 15, 2015 10:04 PM
mustangman65_79
Aug 8, 2015 12:07 PM
