idle to high
Old Jul 29, 2002 | 06:50 AM
bluegoose's Avatar
Car: Firebird
Engine: 383
Transmission: 700R4, lots of Mods
idle to high
Hello all,
I have a 1989 Firebird, 305, TBI, VIN Code E, with Calif emissions. I have a question about the idle, I've been haveing problems with the idle rpm. Its seems to be erratic. I can be driving down the road and let off the gas and still have high idle, I put the car in neutral and I have 1500 rpm. Next I replaced the IAC valve and adjusted it with no luck. So I put the ECM in diag. mode which extened the IAC and disconnted the connection, takeing the IAC out of the TBI. I am still haveing problems, its weird, when driving the RPM is ok, when I left off the gas it still has high rpm then I step on the acceraltor and then the idle goes to normal. Its like haveing an a spring choke. I have no idea whats going on here, I have no error codes, and the car runs like a champ. All and any information will be greatly appreciated.
Brad
San Deigo
Old Jul 29, 2002 | 07:18 AM
ede's Avatar
ede
is the return spring on the linkage or cable working ok, no binding? throttle blades not binding up, timing ok?
Old Jul 29, 2002 | 07:39 AM
bluegoose's Avatar
Car: Firebird
Engine: 383
Timing is ok, will look at springs and butterfly blades. Do you think it might be the TPS?
Old Jul 29, 2002 | 07:45 AM
ede's Avatar
ede
would be something to look at, i doubt it, but i'm not that good with the ecm stuff. check it, or reset it and you'll know for sure.
Old Jul 29, 2002 | 11:17 AM
bluegoose's Avatar
Car: Firebird
Engine: 383
timing ok, springs ok, linkage ok, TPS is ok..everything checks out. any other ideas, anybody
Old Jul 29, 2002 | 01:51 PM
mtccl's Avatar
Check for a vacuum leak. Mine was the intake manifold gasket. Erratic idling, loping, not to mention the oil seepage.
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCtometal
Sep 2, 2015 02:01 PM
