bad fluid or tranny?
Old Jul 29, 2002 | 11:39 AM
Zirtbow's Avatar
My car sat for 7 years and my tranny fluid is a darkish color... I didn't change it yet... thinking about a powerflush... anyway... its an automatic and if ->I<- change gears sitting there with the shifter then it goes BUMP .. the whole car does a breif shake and its in gear.. does it for any gear I shift into.. but if i'm on the road and its changing (automatically?) there is no bumping of any sort... so whats wrong..
Old Jul 29, 2002 | 11:53 AM
chuck6860's Avatar
torque arm
the bumping that you hear is your torque arm, that runs parallel to your driveshaft, you may want to check the torque arm bracket and make sure that the bushings aren't worn or damaged, that should fix it.
83 Crossfire TA
Jan 3, 2016 01:26 PM
greenyone
Sep 2, 2015 03:39 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
masonta
Sep 1, 2015 06:40 PM
spaigo
Aug 21, 2015 07:46 PM
