Popping sound coming from front end... Any ideas?
Old Jul 29, 2002 | 02:33 PM
Fred91GTA's Avatar
Car: 1991 GTA
Hi guys... been having a wierd problem. a few months back, driving home from school, my car started to make kinda like a "popping" sound whenever I would hit the brakes. The sound would come from my front end, and it sounds more like it's coming from my right front wheel. I'd step on the brakes and hear a POP. Loud enough for me to hear from inside while driving and I have my windows down. Car brakes and steers perfectly, so I'm stumped. Could it be the tie rods? any ideas guys? Thanks
Fred
Old Jul 29, 2002 | 04:41 PM
si_camaro's Avatar
Car: 85 Z28
Engine: LG4 modified
Sounds like it could be suspension related, as the sound seems to occur when the car leans forward under braking. From experience of a similar problem, I replaced the lower swivel joints and it went away. I say jointS because suspension noises tend to travel through metal parts, and appear to be coming from somewhere other than the defective part.
As a side note, I also had a "creaking" sound which was cured by tightening the bolts securing the front wishbones to the car. Worth a shot I guess.
Other than that, try spraying some WD-40 on your bushes, one by one, and driving round the block. If it's one of those, the WD will allieviate the problem (not fix it) to allow you to buy the right one.
Hope that helps...
Si
Old Jul 29, 2002 | 04:57 PM
WaynesRS's Avatar
Sounds like your pitman arm or idler arm .
Frozer!!!
Jan 19, 2024 04:55 PM
RazorN8
Jan 7, 2022 11:44 AM
B_Dubya
Aug 26, 2015 05:09 PM
db057
Aug 22, 2015 08:17 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
