Antifreeze INside car help!!!!
Old Jul 30, 2002 | 06:06 AM
Tbird's Avatar
I dont knwo what happened my car got low on coolant in the reserve tank, and it like started to pour steem out of the vents then i noticed anitfreeze was comming in the passesger side what the heck is going on??? I got a 87 z 305 carb..
Old Jul 30, 2002 | 06:12 AM
EvilCartman's Avatar
Car: '82 Z28
Sounds to me like you need a new heatercore
Old Jul 30, 2002 | 06:17 AM
jfox55's Avatar
I second what evil cartman said. YOu need a heater core man. Have fun.
Old Jul 30, 2002 | 06:34 AM
FyreLance's Avatar
Car: 00 TA, 91 Formula, 89 RS
Definitely heater core.. I had the same problem. Came out in the morning and there's a big puddle of Ecto-cooler in my passenger side foot-well.
I ended up bypassing mine and was gonna fix it before it got cold, but I sold the car instead.
Old Jul 30, 2002 | 06:47 AM
Tbird's Avatar
damn, how much is a new one or how can i just by pass it im trying to sell the car anyway and antifreeze wont look to good when someone is lookin at it ...
Old Jul 30, 2002 | 07:02 AM
Tbird's Avatar
guess i shoulda used the search buttom, but looks like i can connect the red-black hoses that go into the firewall looks like a pain to change it...
Old Jul 30, 2002 | 08:43 AM
VampireHunterC's Avatar
Yes, you can just connect the two hoses and bypass the heater core completely. As far as changing it, I don't know. Haven't looked it up in my manuel yet. If it is like every other car tat I have owned, however, it probably involves dissassembly of the dash.
Old Jul 30, 2002 | 10:03 PM
jfox55's Avatar
My 84 does not require taking apart the dash, as a matter of fact the guy who sold me my camaro had just changed it.. He said there is only like 4 bolt that hold it in and a person who doesn't know **** about cars could change it in about 20 minutes. Just check it out man. It might be just as easy to replace as to bypass. THey are pretty cheap too, and how good will it look when you sell the car and have to tell them your heater system is bypassed.
Old Jul 31, 2002 | 01:20 AM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
One of the first repairs I made on my car when I first got it. Not too expensive. I think I paid Pep Boys $100.00 including core, anti freeze and labor. Hell and I really don't drive in thewinter but I like everything working.
Old Jul 31, 2002 | 03:51 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
Just changed mine today, took 30 min to get it out but I had to bend the tubs on the new heater core to make it fit right. It's a PITA.
Old Jul 31, 2002 | 04:17 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
I believe it is only the 91-92 Camaros that require a massive disassembly of the dash to get at the heater core. Don't just bypass it, fix it properly as soon as you can. It is just good policy to keep your car is the best repair possible, according to your pocketbook.
Old Jul 31, 2002 | 04:22 PM
Speedemon171's Avatar
Car: Camaro
Engine: 350 SBC
Transmission: Five speed
i bought a heater core for 29.99 at my local parts store
Old Jul 31, 2002 | 05:39 PM
thunder87's Avatar
1987 Pontiac Firebird V8-305 5.0L VIN H 4-bbl
Vehicle Level Heating and Air Conditioning Heater Core Service and Repair
Service and Repair
REMOVE OR DISCONNECT
Battery ground cable.
Drain cooling system.
Heater inlet and outlet hoses from heater core.
Right lower hush panel.
ECM attaching screw and move aside.
Right lower I.P. trim panel.
Lower right I.P. carrier-to-cowl screw.
Four (4) heater case cover screws. Upper left screw may be reached with a long socket extension through the l.P. openings exposed by removal of the lower right I.P. trim panel. Carefully lift the lower right comer of the I.P. to align socket extension.
Heater case cover.
Core support plate and baffle screws.
Heater core, support plate and baffle from case.
INSTALL OR CONNECT
Heater core, support plate and baffle to case.
Heater case cover.
ECM.
Heater inlet and outlet hoses to heater core.
Refill cooling system and check for leaks.
Vehicle Level Heating and Air Conditioning Heater Core Parts Information
Parts Information
Part OEM Part Price
Heater Core 52479879 $65.04
Labor Skill
Level B Standard
Heater Core
Replace
With AC 4.2
Without AC 1.9
It's gonna be ugly - 4.2 hours with A/C! Good grief . . .
Old Aug 1, 2002 | 03:10 PM
88ROC1LE's Avatar
It was a pain in the *** changing the heater core in my 88, I almost gave up and bypassed it.
Frozer!!!
Jan 19, 2024 04:55 PM
mustangman65_79
Aug 11, 2015 03:17 PM
Kaweh
Aug 9, 2015 02:54 PM
z28addict8490
Aug 7, 2015 08:48 PM
