Need help with a starting problem?
Old Jul 31, 2002 | 02:02 PM
AF_ONE's Avatar
I have a 1984 TA 305 L69. It starts great cold--all the time. After the engine is hot after a drive, I'll make a quick stop and try to restart, the car does not want to turn over--it cranks VERY slowly then fires up. It always starts, but it sure doesn't sound like it wants too.
Someone suggested "heat soak"--what is that and could it be the problem? I've also been told that the starter does that because theres no heat shield--I can't believe thats normal?
Is my solenoid going dead? Help!
the car only has 30K miles on it and like I said it starts PERFECTLY--all the time when cold.
Old Aug 1, 2002 | 12:50 AM
cdogc350's Avatar
Starter is probably damaged internally and when it gets hot, the metal expands probably making a bad internal connection worse... seen it a hundred times in my shop, same symptoms and it was always the starter
Old Aug 1, 2002 | 08:10 AM
AF_ONE's Avatar
Thanks, I'll be replacing the starter with an AC reman next week.
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 8, 2015 12:07 PM
