Roller Lifters from Vortec?
Old Aug 2, 2002 | 12:18 PM
pontiacZ28's Avatar
Can you use these lifters and cam in a 86 block. The lifters are out of a 96?
Old Aug 2, 2002 | 02:57 PM
BigL350's Avatar
If you already know you have a roller block, the lifters will work. If you're not sure, 86 was the changeover year, so the only real way to tell is to pull the intake manifold off and see if you have the three bolt holes in the lifter valley for the "spider". I don't know if that necessarily means it will have the bolt holes for the camshaft retainer in the front. Maybe someone else can give you a definite answer on that. HTH
KO1
16
Oct 15, 2015 05:00 PM
skinny z
Oct 5, 2015 06:23 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
92projectcamaro
Sep 29, 2015 07:07 PM
dusterbd
Sep 29, 2015 08:40 AM
