Lube for centrifugal advance?
Old Aug 3, 2002 | 02:45 PM
Teddy Z's Avatar
Hey guys/gals...
I was wondering what to use to lube the advance mechanism in my HEI. I found that it was stuck when I put my car back on the road this summer and loosened it up with WD40. It's been good for the last 2 months but seems it's doing it again. Also, I guess to lube it properly I'll have to completely disassemble the distributor? Last time I just took off the advance springs/weights and got at it from the top. Thanks for any input!
Old Aug 3, 2002 | 03:48 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
White lithium, very sparingly.
You are correct, the entire reluctor ("star wheel") assembly has to rotate on the shaft; to lube it you have to disassemble the entire thing.
Fanatic1074
Oct 3, 2022 05:57 AM
djmarch
Oct 2, 2015 10:41 PM
Bigold4x4
Sep 28, 2015 05:21 PM
Damon
Sep 26, 2015 04:29 PM
