Low pitched Whistling sound
Old Aug 4, 2002 | 11:34 AM
Battery's Avatar
Car: 75 & 82 Z-28
Transmission: Saginaw 4 speed
First off I have an 82 z28 CFI with a 3 speed auto.
In first gear it does not make the sound.
In 2nd/3rd, it makes this whistling sound when under acceleration. It does not make the sound when cruising, or when given no gas at all. But the slightest amount of gas will start the sound. It sounds like its coming from the driveshaft/rearend (most likely rear). And it does this all through 2nd/3rd, I am not so worried about something going run (maybe I should be) but it gets very annoying when cruising down streets and really annoying on the highway.
Anyone experienced this problem, or know what it is, it kinda seems like something needs to be lubed up or something.
Thanks in advance.
Old Aug 4, 2002 | 02:58 PM
Battery's Avatar
Car: 75 & 82 Z-28
Come on guys, I really want to fix this problem tonight or tomorrow morning.
Any advice would be great, thanks.
Old Aug 4, 2002 | 03:26 PM
irocbsa's Avatar
If its coming from the rear end then it could be bad axle bearings.
Old Aug 5, 2002 | 01:32 AM
IROCracer's Avatar
that's the supercharger....
heh heh heh...
my bad, I had to say it man.
Kelly
Old Aug 5, 2002 | 04:13 PM
JMDinHawaii's Avatar
I got the same probblem....been doing it for a while now. Mine is howlng from the passenger side rear. I ruled out any kind of bearing or axel problem when I changed out my rear. I noticed the sound when Im going around turns too.
It may sound kinda silly but I'm starting to think its a suspension problem. I'm going to be redoing my shocks, LCAs, and put in SFCs in the future so until then I'm going to deal with it. I don't know if this will fix it but only time wil tell.
Old Aug 5, 2002 | 04:59 PM
ZZsmpch's Avatar
A.I.R. pump line leaking somewhere?
Old Aug 5, 2002 | 10:57 PM
Battery's Avatar
Car: 75 & 82 Z-28
Well please let me know if you fix it, I really want to get rid of this sound.
db057
Apr 28, 2019 07:45 AM
fasteddi
Sep 10, 2015 09:32 AM
Formula_88AE
Sep 3, 2015 01:47 PM
RyanJB
Sep 2, 2015 01:27 PM
masonta
Sep 1, 2015 06:40 PM
