Pics, Cam Swap is Done
Old Sep 10, 2002 | 02:53 PM
  #51
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Originally posted by MetKiss316
Wheres the sounds, postwhore?
lol, in my sig, under hookercomp268 I think, use the zip file one.
Old Sep 13, 2002 | 01:12 PM
  #52
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Mark
Hey Mark, how do you like that weiand stealth intake? Does it look nice? Does it fit under the hood? Does the new XE268 cam have a nice idle lope and run hard and strong. I ask because this is the exact same thing i want to do when i get my 350.
Leigh
Old Sep 13, 2002 | 02:14 PM
  #53
Car: 99 Formula
Axle/Gears: 342
Re: Mark
Leigh
The intake I had to ditch the 1" carb spacer and go from a 4" filter to a 3" one.
The cam sounds nice and lopey around 650 rpms.
Right now I'm at college and unfortunately when I had been driving it the few times I did, my timing was quite a bit off.
Old Sep 13, 2002 | 02:21 PM
  #54
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
There should be 4 lines coming out of your fuel tank, feed, return, canister, & a short one with a check valve on it. The short line is the vent for the tank & the valve is to prevent fuel from exiting the tank on a rollover. Plugging the vapor line should do nothing, mine has been that way for 8 months.
Old Sep 13, 2002 | 02:38 PM
  #55
Car: 99 Formula
Axle/Gears: 342
check your pm's
Old Sep 14, 2002 | 12:52 AM
  #56
Scott_92RS's Avatar
Car: 1992 RS
Engine: 406 Stealth Ram
Thanks for the info! So I guess everyone can disregard my previous post...
Old Sep 14, 2002 | 02:53 PM
  #57
camaro89rs355's Avatar
Car: 89 Camaro RS
Engine: 355 TBI
BUY SOME WHITE WALL CLEANER AND MIX IT 20% CLEANER AND 80% HOT HOT HOT WATER
Old Sep 14, 2002 | 02:56 PM
  #58
Car: 89 Camaro RS
Engine: 355 TBI
HOW ABOUT TAKING SOME RUBBER HOSE AND ROUTE IT THROUGH THE BOTOM OF THE CAR FOR THE VENT ON THE CANISTER.
Old Sep 14, 2002 | 05:33 PM
  #59
Car: 99 Formula
Axle/Gears: 342
Originally posted by camaro89rs355
HOW ABOUT
How about taking off the caps key. My friggin ears.
1984HO
Mar 19, 2021 11:59 AM
Cameeeero
Sep 18, 2015 04:00 PM
gta90
Sep 15, 2015 04:00 PM
theurge
Aug 21, 2015 12:46 PM
cstrobel65
Aug 15, 2015 10:19 AM
