350 block
Old Aug 6, 2002 | 09:46 PM
1986z28's Avatar
Car: 86 z28, 87 IROC, 88 sc, 93 z28
Engine: LG4, LB9, LO3, LT1
Transmission: 700r4, T5, 700r4, 4L60
Axle/Gears: 3.73, 3.45, 2.73, 3.42
350 block
When the heads changed it 87 does the block remain the same?
I am just trying to find out why pistons and crank kits say 1968-1986 i always thought that just the heads changed. and if i rebuild a 350 block that had centerbolt heads will the old style heads bolt to the block? Any help would be very appreciated!!
Old Aug 6, 2002 | 09:54 PM
ede's Avatar
ede
the differance is one or two piece crank seal
Old Aug 6, 2002 | 09:57 PM
1986z28's Avatar
but would heads, intake and cam for a pre 86 350 work with it or not?
Old Aug 6, 2002 | 11:54 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
From what I've picked up, 87+ had 1-piece rear seal, different angle on center intake manifold bolts and , roller cams (on pass cars).
I believe the heads will bolt to the block ok.
Old Aug 7, 2002 | 10:31 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
86 and up blocks had 1 piece RMS
87 and up cast heads have the center intake bolt pairs on an offset angle, vette aluminum heads still retained the 90 degree angle though.
Your stuff will bolt up no problem to an old block as long as you use the intake with it. If you use a different intake, just hog out the holes to match and silicone them well.
Old Aug 8, 2002 | 12:26 AM
1986z28's Avatar
sorry what i have written was confusing. What im trying to do is. i want to obuy a holley kit that includes heads, cam, and, intake. I have a 350 that i got from a friend. it is an 89 i believe. the holley kit says that that it requires a 1968-1986 350 block but i dont see why it wouldnt work with the 89 block. Sorry i am trying but i dont know too much on the subject
Jake_92RS
Jan 28, 2020 10:37 PM
theshackle
Mar 5, 2017 06:37 PM
Reborn756
Sep 4, 2015 03:42 AM
Eric-86sc
Aug 24, 2015 09:01 PM
BBSDesigns
Aug 11, 2015 07:39 PM
