how do you tell if roller rockers are self aligning?
Old Aug 8, 2002 | 02:17 PM
nichoulas83Z454's Avatar
i bought a set of 1.6 roller rockers from a friend the other day. they are new, installed but never ran. the brand name is TRE and they are aluminum and have the roller fulcrums.
how do you tell if they are self aligning or not? im thinking about buying a pair of vortec heads if i cant get my pair of 461's to work with accessories.
Old Aug 8, 2002 | 02:42 PM
Dragula's Avatar
Take a look at the roller tip that touches the valve. If it is flat all the way across, then they are not self-aligning. If they have lips projecting down to hold the valve tip between them, then they are self aligning.
Self aligning you do not need to run guideplates. That's why they have the retaining lips.
Old Aug 8, 2002 | 02:55 PM
they are flat all they way across. so can you use non self aligning rocker arms on vortecs if you use guideplates?
Old Aug 8, 2002 | 03:17 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Yes, but you have to have the heads machined for screw-in rocker studs.
Old Aug 8, 2002 | 03:23 PM
cool. i was gonna do that anyway if i were to get a pair of vortecs.
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
KO1
16
Oct 15, 2015 05:00 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
meeklay812
Oct 1, 2015 03:46 PM
