my freaken car still does not start
Old Aug 9, 2002 | 04:24 PM
man_of_steel27's Avatar
Car: 92 RS - For sale
Transmission: 700 R4
Axle/Gears: yup, it has a peg leg
ok i know i have posted before bout my car not starting but i have no clue what it is?
ok engine does turn but it will not start after a few tries the turning over gets smaller and smaller then no turning over.
at first it was i had no connection to my key to the starter, made a few adjustmens. and boom car started, then after a test drive car kept turning off so put it in nuetral and started it again, then finally (lucklel) as i pulled into my street car died and it would not start again. now is just in my garage, thought it might be the alternator but that is good.
i am getting a 350 soon but the guy (family friend) has family issues so not sure when i am getting it but i want my car running even if it is with the 305
thanks for any help
Old Aug 9, 2002 | 04:50 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Fuel? Spark? Compression? That's all it takes, which one(s) is missing?
Old Aug 10, 2002 | 12:34 AM
CALIROCZ28's Avatar
Car: '98 Z28 LS1
Transmission: 4l60E
Axle/Gears: 373
Re: my freaken car still does not start
Have you tested your battery? Is it holding a charge? You stated it turns over very slowly? I would try and check the battery first. Take it somewhere and have them do a full charge on it if the test shows it is still good. You would be amazed what a difference a good battery will do for performance. If it turns out not to be the battery then I would suspect a fuel pump problem. Could be you just were able to make it home in the "Limp Home Mode". Check the battery first and repost on your findings.
Wade787b
Sep 29, 2015 01:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
mustangman65_79
Aug 8, 2015 12:07 PM
L98GTA87
Aug 5, 2015 11:02 PM
