Need Help Quick - Real High Idle
Old Aug 9, 2002 | 06:38 PM
82CamaroZ28's Avatar
Car: 1982 Camaro Z28
Engine: Self-built 350
Transmission: Pro-Built 700r4 w/2800 Vigilante
Axle/Gears: Eaton 3.73 w/Moser axles
I just changed my intake to an Edelbrock Performer and now that everything is re-attached, the car starts, but the idle is extremely high...about 2k higher than where it should be. I'm new at working on my engine...what could be doing this and how can I fix it.
Matt Kaliszewski
82 Camaro Z28
LG4 Automatic
4-BBL
Old Aug 9, 2002 | 09:35 PM
Buck268's Avatar
2000 rpm's to high? Its idling around 2500-3000 rpms?!?!?
IF you mean that your idling aroudn 1000-1500 once warm, I'd guess CTS, but I dunno if its above 2000....
Old Aug 9, 2002 | 10:13 PM
NCZ28's Avatar
Make sure you have all the vacuum lines hooked up, it could be a vacuum leak.
Old Aug 10, 2002 | 10:01 AM
Yes. I turn the car on and it jumps right up to 2500 and stays there. I dont know if maybe the choke is stuck, but I'm not sure how to check or fix it.
Old Aug 10, 2002 | 11:32 PM
Buck268's Avatar
I'm guesssin its carb'd? Have you tried to adjust the idle screw?
Old Aug 12, 2002 | 07:35 AM
86SCBNJ's Avatar
Check for a working choke, also check that the idle kicker is not on (locatd by the throtle cable, in front). Both of these combined can give u a high idle. The carb will not kick down once its up to temp. if the idle kicker is activated....
Old Aug 12, 2002 | 11:46 AM
Thanks for the suggestions.
When I installed it, I put the new gasket on the intake and put the carb on, but realized that the bolts were too long. I then decided to put the old gasket on () so I would be able to tighten the bolts.
This is when it wouldnt drop below 2500.
The next morning I took off the carb and was comparing the 2 gaskets and both manifolds. The old manifold has individual chambers and the gasket was one big hole. The new intake had 2 separate, undivided chambers and the new gasket had individual holes for the primaries ans secondaries.
I put the new gasket with the individual holes for the primaries and secondaries on and put a few washers under the head of the bolt and everything was once again fine.
Infested
May 22, 2018 11:56 PM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
mike_c
Aug 27, 2015 04:32 PM
Hello, Michael
Aug 20, 2015 03:19 PM
